isuzu mu speedo trouble
For all Isuzu related topics
joshdh
Newbie
Newbie
Post by joshdh »
Hey i have just purchased a 1993 isuzu mu 2.8 turbo diesel.
The engine and gearbox have been replaced with a later model (not sure of exactly which year), 3.1 tdi engine and 5spd manual box out of a bighorn..
the problem i have now is that the speedo cable is not compatible with the gear box..
obviously i have thought of just getting a bighorn cable but will this plug into the back of my dash?
Would an auto electrician be able to sort out this problem?
any help would be much appreciated , Cheers :o
Drurban
Re: isuzu mu speedo trouble
Post by Drurban »
Hi joshdh,
Only thing I can think off is you need to get a Big Horn speedo and put it in, I would write what is on the Mu speedo and wind it to the correct settings.
Iam not to sure if this is a way of doing this.
I dont think an auto electrician would know what to do.
Iam sure someone will comment on this so dont take my word for it.
taitantoyota
Post by taitantoyota »
in what way is the speedo not compatible mate? it is to short? wrong fitting?
have you just bought it? have you had a look underneath to see if its all plugged in? pick a part for the win, go pull out a mechanical sender uni
Mattman
Post by Mattman »
The gearbox in my 3.1 bighorn runs an electronic sender instead of a cable.
The later mu's had the 3.1 so you should be able to work out something compatible.
Matt.
joshdh
Newbie
Newbie
Post by joshdh »
hey thanks for the help guys.
The speedo cable is too short and the cable is not compatible with the plug to the gear box..
As far as i know that is the only problem..
Return to “Isuzu”
