Which Air Cleaner for a Holley Carb Snorkel setup?
- MNC
Interested to hear what sealed Air Cleaners people have used or would recommend on their snorkel setups.
I need something that would mount on a Holley Carby and has a single circular air feed diameter of 3" (or is able to be cut open to 3").
Re: Which Air Cleaner for a Holley Carb Snorkel setup?
my 40 series has got an enclosed aircleaner with a 12 x 3 1/2 inch filter ducted back through the firewall and takes air from inside the cab, the aircleaner lid has good clips and clamps down pretty tight, its awesome to keep the filter clean in mud but I wouldnt trust it submerged under water
My flatdeck I used to mostly just run a 14 inch k&n filter with a foam prefilter, it worked well and let the engine breath but was shit in mud and water, some people set up tight fitting shrouds under the bonnet that encloses the aircleaner when the bonnet is closed and draw air down through the bonnet scoop.
When I was going to be in mud or deepish water I'd hook it back up to the standard cruiser aircleaner and snorkle, that setup was well sealed and worked well in mud and water, the trucks half way through an engine transplant to a later model injected engine so I dont know how we're going to set up the air intake yet?
- MNC
Sadam_Husain wrote:my 40 series has got an enclosed aircleaner with a 12 x 3 1/2 inch filter ducted back through the firewall and takes air from inside the cab, the aircleaner lid has good clips and clamps down pretty tight, its awesome to keep the filter clean in mud but I wouldnt trust it submerged under water
Cheers Sadam, this looks like what I'm after. What is that aircleaner out of?
- muddyhilux
my mate used to have a setup like this,worked well and i plan on doing the same but with twin inlets to twin 3" snorkels
- MNC
muddyhilux wrote:my mate used to have a setup like this,worked well and i plan on doing the same but with twin inlets to twin 3" snorkels
Yeah, that looks like it would do the job. I'm after something ready to go... might be a bit lazy but the less mods I have to do the sooner I'm out in the mud.
I'm actually wondering if a single 3" snorkel will get enough air to my 4.2ltr straight 6 2F landcruiser engine...
Your twin snorkels with be sweet - guy in our club has done that and it works a treat on his 350 chev (looks good too).
There was a guy on the surf forum that made up a small box in the engine bay and put a panel filter, had a 304 motor and didn't take up much room in the bay and he reckoned the air flow was perfect. Tried to look but couldn't find it.
- MNC
gimmemud wrote:There was a guy on the surf forum that made up a small box in the engine bay and put a panel filter, had a 304 motor and didn't take up much room in the bay and he reckoned the air flow was perfect. Tried to look but couldn't find it.
Cheers Tim, I'm really after something factory that I can just bolt on to save time.
- muddyhilux
ive looked around to see if anyone sells them off the shelf but didnt really come up with anything so may just get one fab'd up at the local round the corner out of stainless or something
and as for single or double not too sure,there's probably some calculation that could work it all out for you but yeah
MNC wrote:gimmemud wrote:There was a guy on the surf forum that made up a small box in the engine bay and put a panel filter, had a 304 motor and didn't take up much room in the bay and he reckoned the air flow was perfect. Tried to look but couldn't find it.
So that you can put more time into the lexus
you need to broaden your horizons Matt
http://www.jegs.com/p/Spectre/Spectre-M ... 3/10002/-1
oops...now you have to decide which one!! hahhahahhahha
- MNC
gimmemud wrote:MNC wrote:Cheers Tim, I'm really after something factory that I can just bolt on to save time.
So that you can put more time into the lexus![]()
More just so I can quickly finish the brown truck and go wheelin'
MNC wrote:Cheers Sadam, this looks like what I'm after. What is that aircleaner out of?
dunno what it came out of it would have been some old american car, that jegs link wop put up would be worth having a good look through. The other setup I always liked was petefj40s pod filter in an enclosed box hooked up to his snorkel
- MNC
wopass wrote:you need to broaden your horizons Matt
Dont think I need anything that flash though. Not sure I could handle the wait for it to arrive from the States either
Cheers Ben
- MNC
Sadam_Husain wrote:MNC wrote:Cheers Sadam, this looks like what I'm after. What is that aircleaner out of?
OK, cheers. Will keep an eye out on Trademe.
Yeah, Pete's setup was mint but am trying to avoid fabbing anything up.
Yeah, Ben came up with the goods for sure
MNC wrote: . Hopefully I can find something in NZ though.
i been watching for ages and the only ones that came up were beat up shitty plastic ones or chopped up tin ones and for the same money as the shiney new tripple chrome plated ones from the states were worth and they include a high flow filter!!...so i ordered one
Postage shouldn't take that long either. Bought a set of pipes for my bike in aus from the states on a thursday and they were at my door on monday.
- MNC
wopass wrote:MNC wrote: . Hopefully I can find something in NZ though.
Its pretty tempting... under $500 so no GST. How much was shipping?
mines comming with a bunch of other bits through a friend so not sure yet, lol. and its surface freight so takes a cople weeks or more
i think Jegs will only priority freight which is pretty expensive? but fast!
- MNC
wopass wrote:mines comming with a bunch of other bits through a friend so not sure yet, lol. and its surface freight so takes a cople weeks or more
Just did a trial run to check out shipping costs - USD158 for shipping alone
Was no other option for surface freight
- ClassicCruiserSpares
- Sausage Shack
A single 3" snorkel will be more than enough, depending on the aircleaner setup and how its made.
