if i do a 2 inch suspension lift
if i do a 2 inch suspension lift do i need to replace any brake lines or extend drive shaft on m 87 hilux surf on 31s ??
- tomsoffroad
- Flopsie
Re: if i do a 2 inch suspension lift
Yip to both sorry
tomsoffroad wrote:Yip to both sorry
oh really gay thats not good is there any way around it
- tomsoffroad
- Flopsie
Not really unless you rip out the leaves and link it
You could probably get away with the standard hose until you flex the suspension. Then she'd be all over. Same With the d/shaft. The rear axle swings towards the front so it wont fall apart but will probably vibrate and will wear quicker at the slip joint cos there will be bugger all contact there. The front also swings forward an will constantly fall apart at the slip joint and will plain f#@k you off
Been there.
- tomsoffroad
- Flopsie
Sorry just read your post again. You wont have an issue with front d/shaft. Want me to sas it for you
sas ?? so i would need to extend brake lines and extend rear drive shaft
vinceparts
S solid
A axle
S swap
A axle
S swap
how much ??
- tomsoffroad
- Flopsie
Bout $1000 labour if you supply all the parts.
You dont have time for that tom youve got a cruiser to finish
Didn't barbie drive a jeep??
- tomsoffroad
- Flopsie
Fakey
Post subject: Re: if i do a 2 inch suspension lift
Mahahahahahaha
