im new to 4wd and diffs but from the research i have done its a
c200 ratio 4.8
trans axle code CA48
correct me if im wrong but CA standing for c200 and 48 standing for ratio 4.879?
this is the truck
thanks, Tony
charo249 wrote:Can open up your diff yourself just drain oil and pull the cover off the back, if you put it on axle stands and rotate the wheels you should be able to determine whether it is the crown wheel and pinion or the spider gears causing the problem (look out for chunks of metal on magnetic drain plug when you pull it out as well).
As long as it isn't the pinion cog (the little one the drives your crown wheel) I can sell you the parts for much less than $500.
The 4 spider diff head is out of a Terrano/Pathfinder and has new bearings on it and I would sell for $200.
The 2 spider diff head is out of the front of an old Nissan Safari/Patrol and I would sell it for $90.
it was the pinion
it was the pinion
The 4 spider diff would be a stronger however it depends on how much you want to spend, I will also bolt the 4.8 ratio crown wheel to either one of these diff heads for you (may sell crown wheel by itself if that is all you need). Also note that neither of these have an LSD, but then most Terrano diffs don't either and even the Navara LSD's can be hard to track down.
