leaning suzuk?????
For all Suzuki related topics
Mr Zuk
leaning suzuk?????
Post by Mr Zuk »
So my sj been leaning a little bit to to drivers side for a while but have just noticed after a trip this weekend it is leaning more!
Anyone know how to fix this???
zukmeista
Re: leaning suzuk?????
Post by zukmeista »
swap springs around until it's ok? Most of them do it, its just easier to get used to it :lol:
mudslut
Post by mudslut »
Mr Zuk wrote:So my sj been leaning a little bit to to drivers side for a while but have just noticed after a trip this weekend it is leaning more!
Replace the springs with aftermarket springs that are matched left and right hand side to correct the lean
suzookyman
Post by suzookyman »
Sounds like you need a set of these :D 8) http://www.trademe.co.nz/Browse/Listing ... =372974356
Mr Zuk
Post by Mr Zuk »
Already have a rather large lift kit it in it with munroe shocks.
http://www.offroadexpress.co.nz/4wds/87-sj413
suzookyman
swap your front springs over and see if that helps if not your springs may need to be re-set.
lincooln
Post by lincooln »
the other thing you could do is either lose weight or get a fat GF to sit on the other side. :lol: :lol: :lol: :lol:
Just joking :mrgreen:
Sorry I couldn't help myself
Lubrication Specialist
Lubrication Engineers
suzookyman
lincooln wrote:the other thing you could do is either lose weight or get a fat GF to sit on the other side. :lol: :lol: :lol: :lol:
:lol: :lol: :lol: :lol: :lol:
UBZ
Post by UBZ »
seeing as your zuk looks like it's SPOA
I'd say the leafs are stuffed from warp and excessive flex
Mr Zuk
Post by Mr Zuk »
Whats SPOA?
UBZ
Post by UBZ »
Mr Zuk wrote:Whats SPOA?
Spring over axle
SJ's are SPUA (spring under axle) from factory. so yours has been modded with a different suspension setup.
SPOA gives good ground clearance and good flex but is hard on leafs and shocks in a SJ setup
Return to “Suzuki”
