The input seal on my hilux steering box is leaking. How hard are these to change? Looks like I can take of the flange on the input side (4 bolts) after taking off the steering shaft. Is the seal on the input shaft just an o-ring or is it more complicated than that?
Pete
ln106 steering box input seal
Re: ln106 steering box input seal
Not sure what you one looks like but heres a pic of a 70 series one I rebuilt
Theres the input seal, has to come out from the inside I think (was a while ago)
Didn't barbie drive a jeep??
By the looks of the pics, the outer ring is a lock nut. This must be slackened off first and the whole seal carrier is wound out using the little holes as a fix point. Using a pin spanner this is easy. I have a multi fit tool for such a job because I do lots of steering and hydraulic rams. The seal looks like a "common garden variety" lip seal that can be obtained from any seal shop.
Tip, put some electrical tape over the splines to protect the new seal when reassembling
Easy job
Easy job
Yeah I got all the seals to do that box for $16 from seal imports
Was a pretty easy job once I figured out how to get it apart
I didnt have a fancy tool to undo it, I just used a small punch to carefully loosen it off then a pair of poly grips to undo it
