motor spline for warn winch
hi well ive been looking for an alternative for the expensive warn motors (yes i know they are great motors as i have the 6hp model) and the main problems were different shafts key and splined so ive been serching and found the runva model motors have a splined shaft that looks the same size, but my question has anyone every tred fitting one to a warn, do they have the same spline pattern.
Re: motor spline for warn winch
I'm looking into getting an adapter plate made up that will allow our 6.6hp motor with the electromagnetic brake to be fitted to a 8274 top hat
Brett
Tigerz11 NZ
Brett
Tigerz11 NZ
I think Come Up motors fit, check with Papakura Auto Electrical...
I have used one on my Warn 9000i but for me I need to tweak it a bit...
They bolt straight on for the low mounts.
Calvin
Calvin
http://www.offroadexpress.co.nz/oreforums/viewtopic.php?f=4&t=18046
well after a bit more searching i found this looks like it will work with a small mod.
