how to adjust viscous fan hub to lock up earlier
Posted: Mon May 09, 2011 10:06 am
by vinceparts
my hilux surf 1kzte viscous fan hub never locks up , i have replaced the oil in it and it hasnt done eff all, i would like ot adjust it to lock up earlier, how do i do this?
cheers vince
Re: how to adjust viscous fan hub to lock up earlier
Posted: Mon May 09, 2011 10:11 am
by Pedro
vinceparts wrote:my hilux surf 1kzte viscous fan hub never locks up , i have replaced the oil in it and it hasnt done eff all, i would like ot adjust it to lock up earlier, how do i do this?
cheers vince
pull the fan off the motor, apply heat from heat gun to spring on front of viscous, see which way the valves turns, you then need to pull the other end of the spring of the ali housing,and tweak the spring to make the valve be "on" more when the spring is put back into its seat, if you over do it then the fan will never turn off. tweak it back then
did it yesterday to a rover viscous
Pedro
Posted: Mon May 09, 2011 10:22 am
by vinceparts
so if it moves clockwise i need to make it move more clockwise , and by tweaking the spring you mean, streting bending or will there be adjusting nuts of sum kind to reposition it?
Posted: Mon May 09, 2011 10:35 am
by UBZ
what oil did you use? cheap stuff or Toyota OEM
Toyota viscous fan oil comes in 3 different grades/ viscositys , and quantity must be exact.
you shouldn't need to tweak the hub at all
Posted: Mon May 09, 2011 12:02 pm
by vinceparts
i just poured 3/4 of a bottle of that bnt shit in there, what do i need to do exactly and how do i do it and what parts do i use
Posted: Mon May 09, 2011 1:41 pm
by UBZ
there Is a thread on toyotasurf.asn.au that gives all the Toyota part numbers and a full right up
Posted: Mon May 09, 2011 1:47 pm
by DieselBoy
Or just buy a new viscous hub for $120 from BNT. Problem solved.
Posted: Mon May 09, 2011 1:53 pm
by vinceparts
woah didnt realise it was that cheap for a new hub, i can get good discounts too so new hub it will be
thanks
