wanted, guard extensions
as per title, going to br fitted to a 70 series, what have you got or do you know where i can buy some from? cheers, tim.
Re: wanted, guard extensions
Go to bunnings, they sell this plastic stuff for running round the edge of your garden, works primo and is only about 25 bucks for about 5 meters of it, found out about it on this site, running it on my truck and it's proven to be pretty bullet proof.
do you get wofs with that fitted??
cheaper than what some guys are wanting for stock flares for a surf
Yup, no probs for wof, just recently got a cert, and had no issues, my wof guy says they're fine so long as they cover the tires and dont have sharp edges that could cut the old people you might mow down.
problem with garden edging is when you get up against a rut or bank it won't flex. it just pushs in untill the mounts rip out or the panel deforms.
rubber is a much better option IMHO
LR110 ..... LJ50 project
You can get flexi rubber flares from NZ bus and Truck,
Buy it by the meter....
Buy only what you need...
Don't need to buy a box just to replace one if it gets damaged.
Always in stock....
Calvin
Always in stock....
Calvin
I use conveyor belt. Its fibre reinforced and can take a bit of a beating while bending out of the way of stuff that can damage more rigid guards/flares.
ive got some lino flooring off cuts, flexy, tough and cheap, what do you reckon?
To Boon or not to Boon.
I have 5m meters of of the wide actual guard rubber that i got for the jeep that never got put on. you can have it for what I paid if you want. (cost)
toymota thats stock standard.
Pararubber sell a flexiflare type rubber extrusion as well.
Pararubber have a range of widths and thickness. Buy it by the meter, good and flexible.
what do they call it?
I cant seem to find it on the website
5L+GT35@21psi= 223RWHP
5L+GT35@30+psi= 287RWHP....
Great tow Vehicle!
Great tow Vehicle!
