hi
im have removed my diesel engine and fitting a petrol in its place. i allready have a pump to fit in the diesel tank but am not sure what to use to flush out the diesel tank and lines?
what have u guys used to flush them after draining empty?
i suppose a very little of diesel residue wont harm anything (injectors)?
cheers in advance guys
petrol engine using diesel tank
- jonossiksilvia
Re: petrol engine using diesel tank
jonossiksilvia wrote:hi
I just gave it a quick slush out with petrol then put a full tank in, was a bit smokey for half an hour then was all good.
- jonossiksilvia
[/quote]
I just gave it a quick slush out with petrol then put a full tank in, was a bit smokey for half an hour then was all good.[/quote]
cheers for that - was the smoke caused from the oil content in diesel? if so i guessing no harm for only the short time of burning diesel?
cheers for that - was the smoke caused from the oil content in diesel? if so i guessing no harm for only the short time of burning diesel?[/quote]
yeah by the time I drove it from home to the garage for wof cert it was sweet
- jonossiksilvia
awesome thanks
- dave_ln130
- Bush Crasher
the parafin in desiel is ment to lube as it is pumped through so it wont hurt anything for a small amoutn of time ,yea we used petrol or kero to kleen it out of the truck tanks and gave it a good rub as it can leave residue ,(we cleaned them out because they had desiel bug so we were pretty pedantic about it)
chur
