lights
For all Isuzu related topics
abbo
lights
Post by abbo »
Ha there . My bighorn is having a poo and the lights arent working on low beam...Use it sat nite they didnt come on so put on full and back to low and they fine...Now nothing...Checked all fuses and they are all fine...No wires come off...so bulb...
So if anyone could whats happening that would be good...I need it friday nite to pick up my son......
Thanks abbo
:mrgreen:
Don't have 4wd.
sig
Jeep Jeep
Re: lights
Post by sig »
sounds like the column switch is playing up .
meatc
Re: lights
Post by meatc »
x2 on the above. temp fix, get the CRC with the little white tube attached and spray the crap out of the bottom of the stalk and hope some rolls onto the contacts. Long term pull it out and have a look at the contacts, they may be dirty, bent or worn away.
Even shorter term fix, jiggle the swtich hi low hi low but once going leave on low cause no garentee they will go if you have to dip them from hi.
Suza
Re: lights
Post by Suza »
Mine dose that from time to time (usual only one side at a time) and I find a new bulb fixes it. The bulbs are a two part item so when the low beam part goes the high still works
george.ene
Re: lights
Post by george.ene »
If the above suggestions fail. Pull out the multimeter and start some conituance testing.
My Auto/DIY Blog:
http://www.georgeene.com
kbjj
Re: lights
Post by kbjj »
george.ene wrote:... conituance testing.
:lol: WTF
4WDbits
Re: lights
Post by 4WDbits »
translation: continuity :lol:
george.ene
Re: lights
4WDbits wrote:translation: continuity :lol:
Translation: brain fart on my behalf :lol:
My Auto/DIY Blog:
Return to “Isuzu”
