Hey Guys, just put the 8v carb Vitara in the Samurai but want to know if the carb off my old motor will fit on the G16a.It's just that I know the carb on my old motor is a goodin and I don't know the history of this one.Any help much appreciated
Al
g13B.......G16A QUESTION
suzookyman
Re: g13B.......G16A QUESTION
I used the carb and the manifold. Worked fine and bolted straight up. I spose it could have used a bit more fuel but it ran fine and plugs weren't showing too lean. I never thrashed it but it may have leaned out up top if I'd driven it hard.
G13b is the DOHC motor
I'd say the G13a Carb won't be jetted properly for the 1600, better to get the 1600 carb re-built IMHO
LR110 ..... LJ50 project
g13b is just the block code. Both my B's are sohc.
Oh to be twin cam.
My thoughts were the same as to rejetting. Watching the plugs showed they weren't white from being lean so I left it. Went fine till it did a head gasket.
Yes, you could use the 1300 carb, but ti will definately be better with the 1600 carb. Just get the 1600 one cleaned, it'll only cost you a box if you take it to Kev's carby cleaning services
Oh, the G13b SOHC is usually termed G13ba to avoid confusion
They can be stamped both B and BA and be sohc.
Own a few more and you will see.
Maybe we need to clarify which he has and go from there
- suzukisport
Kev's carb cleaning services have gone up, its now two boxes of beer
I guess we will see you Friday as usual Al.
suzukisport wrote:Kev's carb cleaning services have gone up, its now two boxes of beerI guess we will see you Friday as usual Al.
Bloody recession
suzookyman
yup, im bringing the beer and pizza
MMM pizza
Spit roast for me!
