1995 Escudo
1995 Escudo
Hi there. i have a 1995 escudo 5dr v6 and every morning when i start the car it makes a squeeling noise off and on for maybe 3mins. and now its starting making a noise when accelerating that sounds like a little radio control car is under the bonnet. Truck still runs great and feels normal. any ideas??
Re: 1995 Escudo
It will be a loose fan, power steering, or airconditioning belt, will need to be tensioned or possibly replaced
Re: 1995 Escudo
Would that explain the noise when accelerating??
Re: 1995 Escudo
Yes. It goes away or diminishes when your not increasing in revs right?
Re: 1995 Escudo
Yep, Lift the bonnet and check all the belts for excessive play.
Re: 1995 Escudo
Yes it does swamped. Does that mean fan belt?
Re: 1995 Escudo
JFH wrote:Yes it does swamped. Does that mean fan belt?
Yes or any of the others (if any). Its very easy to tighten up, takes all of 5 min. I have to do mine every few months due to the thrashing I give it. (Just realised that you have the v6, I have the 1600 so might be harder, some one else will know)
If you are really desperate try some CRC stop belt slip, but beware that if your belts are worn too much then they will go bang.
Lubrication Specialist
Lubrication Engineers
Re: 1995 Escudo
lincooln wrote:JFH wrote:Yes it does swamped. Does that mean fan belt?
Lucky for those with a 1600!!!
One belt on the v6 took 3 hands, lots of swearing and a little skin. From memory it was the aircon belt and it still squeels a little as the belt is worn. Might pay to change it if you can afford it.
