Filter
Re: Filter
Yup, I "had to" when I did my body lift because the standard airbox did not match up with the engine inlet anymore. Got very good gains between that and the new exhaust. Can post some pics if you are looking for ideas.
H
H
Re: Filter
Yeah that'd be great. I'm just curious on what to do with the (i'm guessing) some kind of air flow meter that goes into the box that the original filter is in!
Re: Filter
Here you go:
http://www.andante.co.nz/projects/vitara/pics/filter/1big.jpg
http://www.andante.co.nz/projects/vitara/pics/filter/2big.jpg
http://www.andante.co.nz/projects/vitara/pics/filter/3big.jpg
Basically I found a pod filter (at supercheap) that had the right neck size to fit straight on the standard pipe, then used a bit of aluminium to mount the far side and drilled a hole in the end to put what I think is the air temp sensor.
Click the links for bigger pics.
Good Luck
H
Good Luck
H
Re: Filter
Thanks very helpful. Do you remember what the neck size of the filter is?
Re: Filter
Sorry, I can't quite remember, best bet is to take that pipe bit into the shop with you and just push them on there until you find one that fits well.
