Engine swap labour?
For all Suzuki related topics
grey
Engine swap labour?
Post by grey »
Hi, can someone give me an idea of labour/hrs to swap a Samurai motor with one from an escudo or similar? Not really up to it myself so would need a mechanic to sort it..thanks
Swamped
Re: Engine swap labour?
Post by Swamped »
I did it in a half day and I'm no mechanic and don't have all the tools. I had a chain block and know zuks enough though so dunno.
Would also depend on if the mechanic needed to pull the engine out of the vitara too.
Also depends on if a good mechanic does it or if they get their apprentice/cleaning boy to do it.
grey
Post by grey »
Ok thanks for that, so not as big a job as it sounds (to me at least)
suzukisport
Post by suzukisport »
We gave suzookyman a hand last weekend to take out the 1300cc and put in the 1600cc Vitara motor in. Took about one and a half days, all that was left to do was sort out a fan for it, he was able to drive it on the trailer no issues. It was a simple conversion just as long as you can all the right bits.
its as long as a piece of string mate, allow a days labour plus or minus :mrgreen:
UBZ
Post by UBZ »
engine swap is easy , only a mater of hours.
wiring/ecu/integration with factory loom , plumbing , air box mounting , fuel system setup , etc etc etc , can take alot longer if you want it done right , as it should be for a vechile that will undoutably get thrashed offroad.
as Sadam said it's as long a a piece of string , depends how fussy you are.
personally I'd never let anyone do wiring in my trucks . seen to many excellent mechanics bodge the wiring install , then hide it under tape up behind the dash
grey
Post by grey »
Thanks all, very helpful as I'm new to all this
Basically I'm looking for a nice Samurai, not for serious offroad (mainly for farm use but would like it at least capable of a bit more) & was looking at a '96 with a stuffed motor, now thinking it might not be worth the trouble. Couple of others on trademe that might be a better choice.
Anyway thanks again, will no doubt be back for more help soon..
getsum
Post by getsum »
we have a couple of suzukis on the farm im starting on tomorrow,ones parked up with barke issues, so i might check it out and give the owner an offer of $5.95...the other is a later model with muds on it...seem to be better value for money than quad bikes he reckons.. well see :)
suzookyman
Post by suzookyman »
as said, I did the swap last weekend. You could do it in a day with help and the conversion kit. I put power steering in as well which slowed things up a bit .Wirering of the 16v needs to be done by an autosparkyman if you don't want to take it on.
Al
lneil
Post by lneil »
getsum wrote:we have a couple of suzukis on the farm im starting on tomorrow,ones parked up with barke issues, so i might check it out and give the owner an offer of $5.95...the other is a later model with muds on it...seem to be better value for money than quad bikes he reckons.. well see :)
Would that be the Landcorp farm? If so ask 'Tash about them, they're Jimny flatdecks. And one in particular has been given death!!
Smurf
Post by Smurf »
LOL :D she won't like you telling stories on her..
Return to “Suzuki”
