Hi all, still looking at options to improve my low range and came across a few forums referring to tiptronic. So here goes
Would a tiptronic gearbox pull me more towards manual gearing ? as the transfer case is the same between manual and auto (so I believe)
Can you retrofit a tiptronic from a 1999 GDI to a 1997 SWB Auto Pajero 3.5
I know I can get a Marks Kit (rock crawler) ,not quite ready for that option going by forum do's and dont's overseas
Thoughts ?
Auto vrs Tiptronic - low range
Re: Auto vrs Tiptronic - low range
The tiptronic is still an auto gearbox...
What are the don't's from overseas for the crawler gears?
Apparently the gears are way too low for normal 4 wheeling in mud. They are designed for rock crawling at super super slow speeds, thus way too low for normal use ... apparently.
OK, now that I have all the facts at hand , YES Marks Low Range kit the best option. The Forums I was looking at were referring to US sights and to do with rock crawling , my Bad !
Sooooooo , I have just ordered from here today
http://www.marks4wd.com/products/gearmaster/Mitsubishi-extra-low-tc-gears.htm
MFK1745A T/CASE GEARS 3.15:1 MITS 3.5 V6 AUTO
3.15:1 low range transfer case gear set to suit Mitsubishi 3.5ltr automatic models. Kit consists of: New input gear, idler gear, output gear, and instructions. Note: The input gear spline is 24T 26.5mm diameter.
Cool. Please keep us updated on this project as this kit is on my wish / wont list as I have the same vehicle. There are posts on various web sights with mixed comments. Be good to see what a fellow Kiwi as to say regarding instillation and end use.
Cheers MIKE.
Cheers MIKE.
ONOescudo wrote:Cool. Please keep us updated on this project as this kit is on my wish / wont list as I have the same vehicle. There are posts on various web sights with mixed comments. Be good to see what a fellow Kiwi as to say regarding instillation and end use.
Cheers MIKE.
Will do, I too have been holding off but my my last outing made me move the wish to actionable .
Mike
Yea there are a few in NZ that have done the swap so far. All them have great comments. There is a chap in Dunedin I know quite well who did it. I will do it whenever the gearbox comes out next,just hasnm't needed to since I did the clutch a few years ago. The thrust bearingis squealing again now so it may be close!
Basically, 2nd gear becomes 3rd, etc and you get a lower 1st, good for winching.
The only downsides are it is a bit noisier in low range with gear noise.
- Luke Somme Burton
- Stropper
Hi there mytronic. How did puting in the gear reducer go.
Could not get the gears, none being produced at time I ordered so shelved for now. Will re visit soon
I've been considering putting a momentary switch in to lock up the torque converter (for extra engine braking). So far I've chickened out though as I get the feeling the lockup clutch might not cope with the load. I really need to talk to an AT specialist.
The AT computer always immediately releases the lockup whenever the go pedal is released, so this clutch never sees over-run torque. Possibly because the AT hydraulic pressure is low when there's no pedal? I'm just guessing.
I just want someone else to do this before I do!
94 Pajero SWB, 3.5 V6
