Hi beam issues
For all Nissan related topics
Herd
Hi beam issues
Post by Herd »
I have a LWB 1993 EFi petrol. Head light works and hi beams work most of the time. Sometimes when switching on the hi beam, the blue dash light doesn't come on and the right hand head light goes out and the left hand hi beam comes on. Where do I start to look for the fault?
katipo
Re: Hi beam issues
Post by katipo »
I had the same problem in my Terrano. One of the contacts in the base of the indicator/light stalk wasnt contacting properly so i just bent it over a bit. problem was fixed.
crazyclark31
Re: Hi beam issues
Post by crazyclark31 »
take it is a safari?
I had exact same issue while back. After a lot of pissing round tracing it found it was a broken wire in the headlight loom between relay and right head light
Herd
Re: Hi beam issues
Post by Herd »
Yup, the LWB is a Safari.
Dak
Re: Hi beam issues
Post by Dak »
Yup, as in post 2, it will be the switch on the steering column.
