I've already converted to LPG instead of acetylene, but my question is can a tank be set up to use standard compressor air or the air mix used by dive tank shops instead od BOC's oxygen cylinder. I kind'a recall being told something about the purity of the air is an issue.
I am only interested in using the gas plant for cutting, not welding.
If a way can be devised of running the air side of the mixture equation with a compressor or dive tanks (utilising air purifiers etc) it would save shit loads of cash.
Does any one know of a way this can be done?
