Cold weather effect on diesel
Posted: Thu May 26, 2011 6:53 pm
by muddy
I'm planning a mid-winter trip up through Rainbow station to Lake Tennyson, with an overnight at Sedgemere (just below Island Pass). Expecting it to get pretty cold, possibly as low as -15 or more. I'm after advice as to whether I should be adding some sort of anti-freeze to the diesel. Aviation Kerosene has been suggested. Any advice?
Re: Cold weather effect on diesel
Posted: Thu May 26, 2011 7:09 pm
by mylux
You will be fine as they add a anti freeze to all diesel that is sold in the winter months.
So if fill it up on your way and all will be sweet :D
Posted: Thu May 26, 2011 9:04 pm
by basics
minus 15 isnt all that cold, you should be fine.
Posted: Fri May 27, 2011 7:51 am
by mikee
-15 in New Zealand really :?: :shock:
Posted: Fri May 27, 2011 10:03 am
by albundy
mikee wrote:-15 in New Zealand really :?: :shock:
Yep, especially in the south island. Several years ago we ran a winter trip to Reefton, the warmest morning was -10, the coldest, -14. Hoar frosts and all the mud holes were frozen solid.
Al
Posted: Fri May 27, 2011 10:39 am
by rangimotors
Al
yip gets nasty when its like that because if your wheels break through the top crust its bloody near impossible to drive through it.
Posted: Fri May 27, 2011 3:49 pm
by tallsam66
Your biggest problem could be batteries dieing because of the cold ...make sure thay are in good condition.
Posted: Mon May 30, 2011 6:50 am
by wjw
Al
Theres a good photo of me pushing 1" thick ice sheets with my front tyres :-)
Posted: Mon May 30, 2011 8:09 am
by muddy
I've done a bit of research now... The critical measure for cold weather is Cold Filter Plugging Point (CFPP) which is the temperature at which the wax will not pass through a standard fuel filter. NZ regulations require diesel sold in winter to have a CFPP of at least -6 deg, and that diesel sold in exceptionallly cold climate areas should have a CFPP of up to -15deg.
Historically, the recommended additive to improve cold weather performance is adding kerosine at 20-50% ratio depending on how much improvement is needed, but aviation kerosene has about 10-20 times the sulphur content, and is likely to be very harmful to emission control systems in modern diesel engines.
So I'll be chucking a jerry-can of Jet-A1 into the tank - I doubt it'll upset the old TD42....
Posted: Mon May 30, 2011 5:19 pm
by tweake
if you use jet-a1 or kero in the fuel you will need to put some sort of oil into it for lube. the old diesel it wasn't a big deal but the low sulfur fuel doesn't handle being watered down.
mineral 2 stroke oil is good or light mineral engine oil will do.
Posted: Mon May 30, 2011 5:25 pm
by Suza
You should be fine I used to operate alot through there in winter and it was just about always batteries that gave greif and some times the fuel filters on the Mogs, but not very often. All the other veichels from Hiluxs to Bighorns that I have been in there with haven't been a problem
