Vitara diffs wanted
Vitara diffs wanted
Does anyone have front and rear 26 spline 5.125 or lower Vitara diffs? Mine currently has 4.825 and I need to drop the ratio for larger tyres.
Re: Vitara diffs wanted
I've got the same issue, really keen to do mine at some stage too. I have a 5.12 lsd sitting here that is going into the rear of mine, it's from a 16v, so not 26 spline, but was told you could use the side gears from the old diff to make it 26 spline. Might be worth looking into as G16 5.12 diffs are a dime a dozen.
H
H
kernels wrote:I've got the same issue, really keen to do mine at some stage too. I have a 5.12 lsd sitting here that is going into the rear of mine, it's from a 16v, so not 26 spline, but was told you could use the side gears from the old diff to make it 26 spline. Might be worth looking into as G16 5.12 diffs are a dime a dozen.
H
Nice bit of info there man, I'll keep an eye out for some standard Vitara diffs.
- safaripete
hi i have a rear diff still in zook that will be removed soon 5.12
safaripete wrote:hi i have a rear diff still in zook that will be removed soon 5.12
How much?
- safaripete
no idea man make us an offer mate
- safaripete
how soon do you want it??
No rush, let me know when you get it out.
Is there no front one?
- safaripete
nah i brought it as a roller no front diff sorry
