Bolt sizes for 2" body lift for Terrano?
Posted: Fri May 27, 2011 10:28 am
by Mattnz
Hi all!
I need help on what size bolts need to be cut and how many blocks are required for a D21 Terrano?
email below?
"Thanks for your enquiry.
Yes we make body lift blocks and can supply bolts for body lift. We need to
know how high you want the body lift, how many blocks and what size the
bolts are."
Re: Bolt sizes for 2" body lift for Terrano?
Posted: Fri May 27, 2011 3:08 pm
by Sketchy_Racer
Hey man for a 50mm body lift you will need 10 bolts in total
8x M10x1.25 x 150 long
2x M21x1.25 x 150 long
The rear ones are M12 in the 4 door models but some are M10s as well so may pay to get 10x M10s as well just in case.
-Sketchy
Posted: Fri May 27, 2011 8:56 pm
by chevrolux
or you could just look under your truck...
Posted: Fri May 27, 2011 8:58 pm
by kiwipete
Have a read of my post I did on my body lift. You need to read up all you can as there are a couple of traps to fall in if you are not careful.
Any questions, just fire away.
Posted: Fri May 27, 2011 9:52 pm
by sibainmud
Amen Pete
