After months of looking at options, scavenging the necessary bits n bobs, including a shiny new MIG welder., I pretty much have all I need.
I have a set of bars off a 2004 Navara that I am going to bolt up to this when finished. They will need shortening as they sit proud of the guards by about 100mm each side, but I do not think this will be too hard to do myself.
I have cut up my old winch brackets to use with it to save having to re-drill the mounting holes where it bolts to the chassis rail.
I am considering using the stock bumper mounting irons for added bracing too. I know they are only held on by 2x 6mm diameter bolts, but they will not be taking much weight, if any at all. Just preventing any extra rotational forces when winching/snatching etc.
I have the bulk of the fabrication done today, hoping to basically finish it tomorrow. Angles of brackets cut and tacked up.
A slot is to be cut out of the bars to allow them to sit over the fairlead and act as a WOF man pleaser to prevent people getting caught up on it.
I need to source some 2-3mm strapping steel to make a rectangular insert when I cut the pipe away. Anyone have anything laying about I could scrounge?
What it looked like when I originally built the brackets.
Let the strip out begin.
Bumper and winch removed, spot the leaky ATF hose. That's sorted now!.
Brackets, cut and tacked up.
Side profile (outside)
Side profile (inside)
Winch and plate just sitting there.
Bars sitting place to see how it looks.
Hole for fairlead marked out ready for cutting.
I need to source some suitable 2-3mm thick strapping steel to make an insert for the bars here. Anyone have anything laying about I could scrounge?
I think I will place a 3mm thick webbing between the underside of the winch tray mount and the inner brackets for added strength?
There are more plans in mind for to finish it off nicely too, just need to source some more bits n bobs.
