terrano wheel bearings
grytvikken
HiI have a squel from what appears to be the righ front wheel on my terrano. I am assuming its the wheel bearing, any hints or advice on replacing them? the noise is intermitant and only there at low speeds. Any opinions on what it could be other than bearings would be gratefully recieved. The brake pads are near new
Re: terrano wheel bearings
when you put the pads in did you put copper grease on the back and sides off them? or shity pads squel heaps
if its the wheel bearing, pull it out repack it with wheel bearing grease and adjust her up.
another d21 terrano
ex lancer build
ex lancer build
grytvikken
pack or replace?
i would pack the old one with grease if its not rumbley
another d21 terrano
ex lancer build
ex lancer build
grytvikken
Thanx foir the tip I will try packing them first.
Weird squel tho its only there half the time?
if it goes away while your braking it will be your pads. what type/brand of pad did you get?
another d21 terrano
ex lancer build
ex lancer build
grytvikken
hell cant remember the brand
