Hilux diff help, B04A
Quadstyle
Post by Quadstyle »
Does anyone know much about the newer model hilux diffs im talking in a 2006 2wd running a B04A.
I am needing to replace it but they seem to be a bit hard to come by, so am woundering what i can chuck in instead and what the differnce is to the older stuff if any???
Can i chuck an older diff head in my housing? or can i fit an older diff on my leafs?
Thanks guys!
muddyhilux
Re: Hilux diff help, B04A
Post by muddyhilux »
http://www.brian894x4.com/Gearratiosanddiffs.html
hi mate,check out above sit for info your after,looks like 4.556 2 pinion open,good page and found info to be accurate,hope that helps
