winch to fairlead distance
chrome
Post by chrome »
how far away from the winch should the fairlead be... is there a rule of thumb or just as space allows.
any opinions??
DIRTY OLD HILUX
022 519 7700
haynzy
Re: winch to fairlead distance
Post by haynzy »
the further you go, within reason of course the better it will spool.
chrome
Post by chrome »
yep thats what i thought, im just looking to see if there is a minimum distance really
chhers for the reply
DIRTY OLD HILUX
022 519 7700
haynzy
Post by haynzy »
i think ya wanna aim for about a metre to get it to spool nice
chrome
Post by chrome »
chur make a mean battering ram :mrgreen:
DIRTY OLD HILUX
022 519 7700
kbushnz
Post by kbushnz »
If you follow industry practices, I calculated my Toyota factory PTO would need to be 4m....
But that aint going to happen.
Been told 1m is good.... but for my application can only get 700mm...
Calvin
DieselBoy
Post by DieselBoy »
I have the fairlead hard up against the winch due to space availability and approach angle.
It works fine.
Any distance you can get on it, away from the drum is an advantage.
50mm is better than hard up against the winch, but 100mm is a big improvement over 50mm type deal.
chrome
Post by chrome »
cheers db :D
DIRTY OLD HILUX
022 519 7700
mudlva
Post by mudlva »
once you start getting a bit of distance then you can also start narrowing the fairlead down a bit and that will help stop it from over spooling on 1 side as fast when pulling from the side
you know what i mean :?:
chrome
Post by chrome »
yep makes sense to me, im tryuing to keep it close im sitting around a hundy at the mo
DIRTY OLD HILUX
022 519 7700
