Articulation
- RoloverRover
- Driver/Navigator
Articulation
What is the best and most cost efficent way of gaining good articulation from a s3 109 i have air shocks in it and doesnt seem to bad but i reckon theirs more to be had from it. Any ideas also it has series 40 diffs. I also have a project 2a on the way i am picking it up for free so it is going to be a dedicated offroader what other diffs and springs work well in landi?
BTW heres an idea ive been toying with http://forums.lr4x4.com/index.php?showtopic=4509 look on the second page. Should be be strong enough that I wont do any damage if my brakes and starter motor fail at the same time again while getting the position as a winch anchor
- RoloverRover
- Driver/Navigator
What are you gonna do with the 2a
Most likely put series 40 diffs in it with spring over adapt a form a pwwr steering shorten the back end down so the longest point will be the rear spring mounts take the tray off and fabricate a the litest form of a tray i can put roll bars on it a little bit of work on the 202 to make sure it is going to be a reliable motor. Tyres and from their most likley trial and error to improve on it. 2reasons im using the 2a Nob1 its free Nob2 its light and can be repaired with stollen oven trays from the kitchen
;-p
as soon as i finish my datty ute mate ill hook into it if ya want
just a couple of ideas for you
Re: ;-p
wopass wrote::roll: ... i can just see it now... landi turns up and gets dropped off at my place with all the parts to do the EFI conversion,spring over conversion,AND your gonna want me to do it !.....
as soon as i finish my datty ute mate ill hook into it if ya wanti seem to recall a couple of cruiser diff housings rolling around here somewhere to... or we could pop hilux gear into it ? smaller diff heads = more ground clearance and its not like its as heavy as a cruiser so hilux stuff should be plenty strong enough... cheaper lockers as well
With the rear diff, if you're going with hilux heads, find a fully floating rear cruiser and weld the centre into it. It solves the offset problem and it is much stronger, and if the shaft breaks, you are still safely mobile.
The EFI conversion is really easy. Its just a small bit has to be removed from the firewall (for the manifold) and a new pickup put in (use the old pickup as a return).
- RoloverRover
- Driver/Navigator
Im very keen on the EFI it sounds like the best way to get the torque pm me with how much you would like for it turoa the more i think about it the better it sounds to me and as for the fire wall its not a road going truck so im not worried about it i can patch it up to stop some of the water and mud comin in. As for diffs i like the idea of the lux diffs but Wopass you have seen how im likley to end up driving it i think it would be prudent of me to go with the cruiser diffs less chance of me destroying it ill have to just save the money a bit longer for the lockers. And the pluss side is i know a guy that has got a set that is already set up for spring over!! Im picking up th 2a on the weekend so ill post picks for all to see what i start with at this stage i dont know what condition it is in but nothin is beyond repiar
RoloverRover wrote:Im very keen on the EFI it sounds like the best way to get the torque pm me with how much you would like for it turoa the more i think about it the better it sounds to me and as for the fire wall its not a road going truck so im not worried about it i can patch it up to stop some of the water and mud comin in. As for diffs i like the idea of the lux diffs but Wopass you have seen how im likley to end up driving it i think it would be prudent of me to go with the cruiser diffs less chance of me destroying it ill have to just save the money a bit longer for the lockers. And the pluss side is i know a guy that has got a set that is already set up for spring over!! Im picking up th 2a on the weekend so ill post picks for all to see what i start with at this stage i dont know what condition it is in but nothin is beyond repiar
well best you keep your eyes peeled for a couple of 4.1 ratio diff heads and front axles/swivel housings/disc brakes set up as the housings are Naked(i have axles for the back) and the housings will need to be RE- perched as the ones on them are a bit shagged.... something to do with the rough bastard who used to run them
- niblik
- Sausage Shack
my first 4wd, which is still sittin in the back yard, was/is a 2a.. love it.. lwb ragtop.. olive drab and the good ole lump of a 2 and a quarter litre engine... still strats up sweet as... the best truck in summer.. amble on down to the river with the kids in the back....
woe..................
sorry, thread jackin with a bit of a walk down memory lane..
be good to see this build/mod using 40 axles... the best of both worlds... and a man after my own heart.. nice..
keep it up!
turoa wrote:I have a 4.1 diff for salecame out of a full floating housing but would probably fit a semi
ahh thats right, you have
Building a Series 1 1/2
See avatar.
Running FJ40 diffs on Discovery / Range Rover springs and suspension arms. All with the same view in mind, good articulation available using stock LR suspension components, strong diffs and axles by using Toyota gear. Best of both worlds.
Now why didn't some car manufacturer make em like this...
Don't say it.....
I suppose they are called Nissans
Don't say it.....
- RoloverRover
- Driver/Navigator
lol when you say best of both worlds my s3 runs series 40 diffs and an ld28 that still has a fair bit of pull left in it yet. But it is certed so i dont want to go and mod that to much ill most likley use it as the tow vehicle and trailer this project. At least i have something to measure from for all the set up. Also my 3 has disk rear off a holden
Cloggy_NZ wrote:Building a Series 1 1/2See avatar.
Now why didn't some car manufacturer make em like this...![]()
Don't say it.....
I suppose they are called Nissans![]()
Yep
You lot are making me jealous. There's a certain S1 in a shed that i have been meaning to do some work on..........................
DieselBoy wrote:Cloggy_NZ wrote:Building a Series 1 1/2See avatar.
Don't say it.....
Yep![]()
Not a cream coloured soft top by any chance??
lilpigzuk wrote:DieselBoy wrote:Cloggy_NZ wrote:Building a Series 1 1/2See avatar.
Don't say it.....
Yep![]()
Not a cream coloured soft top by any chance??![]()
You have a surprisingly good memory
Yep, it still drives, just needs an engine recon and either the clutch or selectors in the box looking at. Harder than usual to get gears
Its a mix of the best bits from S1, 2 and 3 these days though.
How about these diff mods
http://www.seriestrek.com/toyotadiffs.html
I, keen to fit some land cruiser diff heads to the series housing , I have a series 1 so I think i'll join the land rover outer axle part with the bearing and wheel flange to the landcruiser end. Still working on a plan for the front axles.
Here is a photo of the hinged front spring mount
looks easy enought to make,
these guys use a 12" travell procomp shock,
The only thing I cant find at a price which will slip under the radar is a long travell d/shaft.
Toyota axles might be good but volvo portals are better especialy under a landy
[/img]http://www.offroadexpress.co.nz/images/albums/Jamuba/blue1.sized.jpeg[img]
[/img]http://www.offroadexpress.co.nz/images/albums/Jamuba/TONK5.sized.jpeg[img]
[/img]http://www.offroadexpress.co.nz/images/albums/Jamuba/TONK2_001.sized.jpeg[img]
portals are gooooood
[/img]
Cheers Reeece
Those rotating front spring mounts have a bolt and tube between the horizantal plates to lock them solid for road driving.
I think that lwb had a RTI score of around 960.
Youll need some parabolics springs, 32" long shocks, new shock mounts, longer brake lines, a high angle yoke d/shaft the ujs are spicer 1310 series, if any one can help with infomation on range rover d/shaft yokes, what I need is there angle of flex, the d/shaft needs to have 6-8" slip joint, and look at the cross member below the trans bell housing as the d/shaft might clash, space your wheels out and bobs your uncle.
I think paras go for $250 rocky mountain from those guys at Manaku 4x4, shocks for $300 those good ones from 4x4 stuff, $600 for a drive shaft, plus wheels or spacers, brake lines, certification, $2k? cheep at half the price. well thats my best guess any way.
Then do the back end
How much $ for a safari?
