low range offroad
Greenzuk
low range offroad
Post by Greenzuk »
With the good exchange rate at the mo i'm thinking about getting some bits from these guys in the US for my 413. Is their samurai the same as our 413?
Rotazuk
Re: low range offroad
Post by Rotazuk »
There samurai is the same as our samurai . Most stuff fits but axles are wider etc .
Chris
zukmeista
Post by zukmeista »
Yes, as far as I know everything will fit apart from things like the cromo axles and C.V.'s which are a different length. Maybe if you listed what you were going to get we could say whether it will fit or not.
UBZ
Post by UBZ »
also be aware of
steering is LHD in the US.
drive flanges / spacers bolt spacing. 413/Sammy are diferent .
sammy transfer case had no parking break attached , brackets etc, may not fit the 413
breaks ,hubs,steering etc sit alot closer to the chassis in the 413.
Sammy front diff is 2 pinion, 413 is 4.
