Surf Tailgate Window Issue
Posted: Sun Jun 12, 2011 7:31 pm
by nt_a_foz
Have got a issue with my KZN130 Surf rear tailgate window.
Theres 2 small channels on the bottom of the window that the window up/down arms slide through to move the window up and down. One of these has rusted out so the arm wheel falls out when the window goes up an down.
Has anyone had this problem and if so what did they do to remedy it?
Is this a part that can be bought from toyota and put back on or just find a channel the same size from a engineer and attach it to the base of the window?
Re: Surf Tailgate Window Issue
Posted: Mon Jun 13, 2011 9:18 am
by UBZ
you will have to pull the window ,etc ,out of the tail gate to replace that part .
my suggestion would be to get a 2nd hand tail gate, pull the internals then swap them into your tail gate.
Posted: Mon Jun 13, 2011 9:52 am
by nt_a_foz
Yeah have already pulled apart etc to diagnose issue so no problem there.
Have talked to Lineside Wreckers/O800MYHIACE and got another rail coming for $25 so all is good.
