I have found a new set of dobson springs (uncompressed about 450mm)aparently about a 3" lift not sure wat a standard spring hight is,
and nitro raw max's shocks, fronts compressed are 430mm ,extended 675mm and the rears compressed are 460mm, extended 730mm. aparently for about a 3" lift also, If i was to put these in would i have to modify or change anything else on my wagon, i am also running 32x12.5s on it as well. dont wont to get to serious, or spend to much just enough to have a bit of fun and get bit of clearance, any advice would be great, thanks
