hilux body lift
hilux body lift
hey does anyone in new zealand sell body lift kits or atleast the blocks for yn65 hilux? did a search on here and after reading the 20 odd pages under body lift couldnt find a supplier. any help would be much appreciated. also are alluminum body lift blocks up to standard for certification? cheers
Re: hilux body lift
Heaps on trademe. Try under toyota parts, lift blocks.
Re: hilux body lift
Yea i saw those on trademe but there all from aussie so the $37 freight on top of the $150 for the blocks is a bit of a killer, then again maybe i should stop being a tight ass
Re: hilux body lift
i got a mate to make mine...cost me $70 for 10...
Re: hilux body lift
Go to www.dotmar.co.nz these guys can sell you the the UHMWPE 60mm diameter rod you need, they can cut it to length & also drill the holes.
Then go to blacks fasteners or somewhere similar & buy the grade 8.8 bolts etc you need.
Thats what i did ..is the easiest way to go & will be cheaper than tardme
Re: hilux body lift
Hey i since got aluminum blocks second hand $70 off trademe cheers guys also pm muddyhilux he can make blocks up to suit aswell!
