external waistgate
Posted: Fri Jun 17, 2011 5:47 pm
by poss682
any one know of any one that would or dose sell externals for a 2.4 t hilux ??
Re: external waistgate
Posted: Fri Jun 17, 2011 6:04 pm
by Lynx
Why bother?
Posted: Fri Jun 17, 2011 6:30 pm
by Big Will
Lynx wrote:Why bother?
x2
run all the boost..
Posted: Fri Jun 17, 2011 6:39 pm
by tweake
have you got an exhaust manifold that you can fit one to ?
Posted: Tue Jun 21, 2011 6:00 pm
by poss682
well it should have an internal so dose that make it compatable with external
Posted: Tue Jun 21, 2011 6:47 pm
by tweake
poss682 wrote:well it should have an internal so dose that make it compatable with external
no.
the stock turbo has an internal but manifold doesn't.
to fit an external you will need to make a custom manifold or some sort of adapter between turbo and manifold.
also i high doubt you could even run a big enough turbo to require an external turbo.
Posted: Tue Jun 21, 2011 7:11 pm
by Big Will
no.
I wouldn't be so sure... Just kidding..
Posted: Tue Jun 21, 2011 7:48 pm
by tweake
at least your running a 3 litre 8)
2.4 diesel is a slug off the line at the best of times, it will be a snail with a really big turbo. better to rip the 2.4 out and fit 2.8 or 3 litre in there.
Posted: Tue Jun 21, 2011 8:29 pm
by Big Will
I would fit EGT, 3" Exhaust, good intercooler setup, Disconnect wastegate an up the fuel to about 520deg..
But that's just me.
