Should i remove front and rear sway bars?
Posted: Fri Jun 17, 2011 10:48 pm
by kyle1234
Anyone give me some advice from experience thanks.
Re: Should i remove front and rear sway bars?
Posted: Fri Jun 17, 2011 10:53 pm
by mud_slinger
front yes get quick disconnects as affects on road handling with body roll get rear disconnects too
Posted: Sat Jun 18, 2011 9:53 am
by pouw
Depends on two factors:
1) How seriously offroad do you go? I used to do the Akas with swaybars on with no issues. Particularly as I see you have a diff lock. Articulation is great, but a diff lock should get you there most of the time with some thought and care.
2) How much of the time is the vehicle on road - in my past experience, removing the swaybars does create quite a bit of roll on the road - noticeable so in a Pajero.
Posted: Sat Jun 18, 2011 11:02 am
by turoa
THERES A SEARCH FEATURE!!! learn to use it there are a number of threads already that go into this!
Posted: Sun Jun 19, 2011 11:10 am
by kyle1234
turoa wrote:THERES A SEARCH FEATURE!!! learn to use it there are a number of threads already that go into this!
DONT REPLY OR READ IT IF YOU DONT WANT TO
Posted: Sun Jun 19, 2011 9:23 pm
by lincooln
If you remove it completely you will run into trouble when it comes to WoF and so on. Will help with a bit of flex. Having diff lock is good. But when you are learning to drive try go without the diff lock as far as you can. helps teach you what lines to take etc.
Posted: Sun Jun 19, 2011 10:00 pm
by red-devil
i wouldn't go doing that, as very quicky no one will help you.
2's is a man with a helalot of info a is very willing to share.
use the search before asking questions please.
