Rear Diff lock light flashing.
What dose this mean when the rear diff lock light is flashing?
- mud_slinger
Re: Rear Diff lock light flashing.
I used to get that occasionally when taking my Pajero out of 4WD. Generally speaking, I used to just go through the process again, put it into 4WD low with diff lock, drive forward a bit, then reverse the process of taking it out of 4WD.
Worked all the time, just a bit fiddly.
As always, do it on gravel
1986 2.5L TD Pajero
Rear light, not the center one?
Your model fitted with the rear locker?
94 Pajero SWB, 3.5 V6
