anyone know if 1jz-gte + manual gearbox will fit in 2wd auto surf (96-02 shape)??
also what do you thinking about sr20 in surf?? this isn't torqy engine i believe??
1jz surf??
Re: 1jz surf??
I put a 1jz-gte in a LN130 surf it was still 4wd though, ran a r151f gearbox so was still 4wd. Ran a Link g4 ecu, steel wheeled turbos yadda yadda, went hard as definitely recommend it. Fitted no probs
collaboration
- Driver/Navigator
Re: 1jz surf??
mean! thanks for the info
i might pm you when i go ahead to get some extra info
