So what is going on?
Injectors have been done last year, has free flow exhaust (just the dump pipe to finish off).
I have yet to check tire pressures but they were okay last time I checked.
Oil was changed from valvoline to ? so maybe its a little thicker and the engine has to work harder. Any suggestions on oil brand etc to use for better milleage while not compromising turbo life etc.
Perhaps the air filter is dirty (it is chch after all) or the new one is more restrictive. Suggestions for a good replacement.
Maybe its time to have another look at the EGR junk and make sure its blanked off (maybe the valve has shifted a litte and now I have gas though it affecting the efficiency).
Maybe the intake is too gummed up with egr gunge and needs a good clean out.
Maybe the Crank breather is pushing more oil vapour into the system and the intercooler is becomming clogged. Perhaps a catch can is another option.
The power still seems to be there and I am not seeing any smoke at all (but I am driving in darkness mostly), have noticed some specks of black shit on the drive from where it starts that I havent seen before.
So any suggestions?
