???samurai/swift g13a dizzy question???????/
OK so the g13 in the swift/barina had a straight dizzy and the one in the sammy has a right angle dizzy. if i use a g13 from a swift can i use the dizzy from the sammy so i dont run into the firewall. ???????????????? also will everything else just bolt up???????????????????/
Re: ???samurai/swift g13a dizzy question???????/
Is the swift engine a single cam? If it is everything should bolt straight up. Swift sometimes doesn't have a mechanical fuel pump and the waterpumps appear to differ sometimes but thats all I've noticed so far.
Can be a bit of a pig with belts swapping over too due to 5 stud pulley rather than a 4 stud but some swifts come with a 4 so you might be lucky. This is where water pump length can be a mongrel.
yes but in pics ive lookd at single cam dizzy is still different (runs parrallel to the engine) will my dizzy bolt up to the swifts dizzy housing
- Rotazuk
G13 swifts up to about 87 ish ran an angle dissy just like the 413 . 87-88ish onwards they are straight . Either way your 413 should bolt straight in . Slim chance you will have to swap cam shafts but I doubt it .
Chris
Chris
