SAS on 1990 terrano: updated 28-11-15
Dirtydog
Post by Dirtydog »
Ok guys,
so this is going to be the project page for the upcoming axle swaping on my terrano.
ive got all the parts lined up, all i need is the adapter between the transfer case and the trans from an auto safari.
The deadline for this project is the end of august.
as the progress carrys on i will post it up here with photo's
sibainmud
Re: SAS on 1990 terrano
Post by sibainmud »
Subscribed :D
Watching with interest.
Big
Post by Big »
ditto :mrgreen:
u13turbo
Post by u13turbo »
x3! so your going to use a safari box and transfer? are the adapter plates buy able from somewhere? what axle are you using? gonna be coiled?
Dirtydog
Post by Dirtydog »
aparently the safari auto gearbox transfer case fits over, but if not i will be getting one machined up, and its going to have safari front and rear axles, im pulling lsd out of rear terrano one and puting it in front diff, and possibly getting a lokka for rear.
its going to be coils all round, so a nice ride, and easy to lift too.
the only problem is its gunna be 4.1:1 ratio, so slugish on road with big tires, but i might get some gears for the transfer case to change it down a bit.
ill be using the tranfer case from an auto safari hopefully, so insted of having the problem of the driveshaft coming down the left hand side, it will come down the right hand side so i can virtually fit most axles under the front, but im going with safari axles as they are nissan, and they will give me a greater track width, which will be handy for stability both on road and off it.
im really looking foward to this upgrade :)
kbjj
Post by kbjj »
Hope this helps. The difference between Terrano auto and manuel xfers, is the auto has a 30 input spline, and the manuel is 24. The Terrano auto xfer also has a stronger drive chain assembly. The different input splined gear can be swapped between the two.
Heres a couple of photos of a Safari auto xfer sitting on a Terrano auto. 1st photo showing the top two bolt holes aligned, and 2nd veiw from bottom.
They dont fit by a mile. My concerns are, that if you make an adaptor plate, the splines wont be fully engaged. If your using an auto box, the rear section of the housing could be chopped and turned into an adaptor. If your using a manuel box, I guess the rear of that will need chopping. Just my thoughts
Edit: I've just found out that the stronger auto xfer case I'm refering to is off a V6
Dirtydog
Post by Dirtydog »
i guess im going to be using a auto box as an adapter then, in which case i will need the full auto.
but ive seen in photo's that the safari auto has the transfer case, then in has another section inbetween the t case and the auto itself? are the photo's from there on or are they just the auto transfer by itself?
but it shouldnt be too hard trying to find a complete unit, and just take what i need from it.
kbjj
Post by kbjj »
I'm not sure what your asking. The photos I've shown are of the Safari xfer, and Terrano auto, no adapters. Maybe there is adaptor housings with adaptor shafts available.
Maybe a Safari box and xfer, adapted to your motor might be easier
slide
Post by slide »
Hi dirtydog, just to clear things up in my head, your terrano- is it an automatic trans? Also have you got diesel or v6?
Dirtydog
Post by Dirtydog »
its an auto diesel, td27.
i dont know if the safari box would fit under a terrano, but i havnt really seen the size difference.
i dont know how to explain the auto box with transfer case adapter, but im going off what rick at 4wd accessories has been saying.
Swamped
Post by Swamped »
It is a cool project but it seems like a lot of work. Why not flick the terrano and buy a patrol or maybe solid ax hilux? It a vehicle weight thing?
I'll be watching with interest too.
Dirtydog
Post by Dirtydog »
i dont like how heavy the landcruisers/safaris are, and i really dont like the bodys either, the safaris are just big and cramped, where as the land cruisers are like a work truck.
i have thought about a hilux but there are alot of them around and i like to feel independant, ive also notice that the hiluxs tend to have less grunt unless they have a turbo on them, but i have seen alot of blown turbo's from toyota's.
i also like nissan, in general, but the things i like most about terrano's is the body, looks the part i guess. and how many people are there in nz with a sas'd terrano compared to sas'd surfs?
Drurban
Post by Drurban »
Yeah it would be good to see a SAS Terrano which will be something new especially for a Terrano.
Cheers.
GotFlex
Post by GotFlex »
slide
Post by slide »
thats some cool pics!
Fakey
Post by Fakey »
Cool project idea, only thing I can see being a problem is that if you want to fit larger tyres is that itll end up being pretty high unless you do a whole heap of cutting. The chassis is pretty flat at the front like most IFS trucks so if you do keep it low itll have bugger all up travel. Just bought one of these d21 sh#tters so will be watching with interest
Didn't barbie drive a jeep??
Filthy4x4
Post by Filthy4x4 »
That terrano looks awesome, it looks tuff as :twisted: :twisted:
027 MUD GEAR - (027 683 4327)
Check our facebook:
Dirtydog
Post by Dirtydog »
it will be pretty high anyway, but as high as it will be it will definitly be wider, so should be alright in terms of stability, but im keeping options open to possibly fit 37's, but most likely have just 33's.
Fakey
Post by Fakey »
KIWI_TERRANO
Post by KIWI_TERRANO »
4wd upgrades have done a navara before eh
sibainmud
Post by sibainmud »
I see a heap of left handed pumpkin jeep diffs, Hmmmm......
Fakey
Post by Fakey »
sibainmud wrote:I see a heap of left handed pumpkin jeep diffs, Hmmmm......
Your IFS is probably stronger :lol:
TD power
Post by TD power »
looked at doing this a few times the best way i looked at it was to just move the pumkin to the left my old man did it with his jeep when he put a safari diff in it good luck
Dirtydog
Post by Dirtydog »
yea but i want the width of the safaris and dont really trust chopping something and re welding it, makes the housing only as strong as the weld.
plus it will be easier if i bang up the diff etc i can just put another safari one under it, not have to get it chopped up.
and those jeep ones are dam expensive to replace, 2 safari diffs cost as much as a dana 30, which is as weak as a terrano front diff, and 5 std.
Fakey
Post by Fakey »
Dirtydog wrote:yea but i want the width of the safaris and dont really trust chopping something and re welding it, makes the housing only as strong as the weld.
You dont need to chop the housing up, you flip the whole housing round, move the swivel balls an diff head studs to suit :wink:
Dirtydog
Post by Dirtydog »
but your still chopping and welding it anyway.
NJV6
Post by NJV6 »
Enough excuses. Now do it! :lol:
Dirtydog
Post by Dirtydog »
lol, yea im getting there, got all the prices worked out etc just have to get the funds together.
not far away now, work starts on it in august, so not too far now.
GotFlex
Post by GotFlex »
hahah can i ask what your budget is? now times that by 3 and you will have enough change to buy maccas on the drive home from cert
Dirtydog
Post by Dirtydog »
ive got 8,000 at the moment, and the work from the welders gunna cost 3,000 including cert, parts are about 2,500.
so ive come under budget so far.
