hah just thought this might help someone and maybe help me also.
I had an issue with clutch slip, the kit included a master cylinder and i thought it a good idea to swap over the pushrod to keep the same size thread. the end of the pushrod was too long and blocked off the fluid return hole!
didnt pick up on this for a fair while haha but wondered why, when she got hot she would slip like buggery.
clutch pedal is a bit of a prick i find, quite hard to push then quite a bugger when its returning, so am going to try a new slave, and see if its out of alighnment, the piston had a fair bit of wear on it any ideas or simalar problems??
Commy V6 Hard clutch pedal, with hot slip Marks kit
Re: Commy V6 Hard clutch pedal, with hot slip Marks kit
Adapter faces could be out of alignment ive come across this issue a few times.
Look here http://www.offroadexpress.co.nz/Forums/ ... ilit=marks
MWB V8 Safari Ute
hey yeah, doesnt seem to be too bad that way, im thinking maybe out of line vertically.
my appologies, it is out of alignment, both ways. what a rip!!
If you have the time send it back to marks as they will not want to know about it after you have had it machined.
I tried making them aware of the issue and they were not interested.
MWB V8 Safari Ute
I have Callumed up the slave to adjust (drilled out), may just try shim it to suit, it has been on the truck for a year now, have finnally had enough of the heavy pedal, its been a complete bastard.
