removing factory e-locker diff head in hilux
Posted: Wed Jul 06, 2011 7:05 pm
hi ive got a yn105r with a factory e-locker diff. the diff lock has stopped working and the seal leaks so ive tryed to pull the diff head out.
ive got it head loose but it wont come out?
i have been doin sum reading and if the the locker is not engauged the diff head will not come out, is this correct?
also the other reason i thourght that it may not come out is because the steel studs that hold the diff head in are longer on the side of the head that has the locker motor on,the locker motor i think has sum alloy parts on it that the studs run through and i think they have seized together? is this feasable that this could have happened? any tricks to freeing these to metals?
any idea would help
thanks
any idea would help
thanks
