Another SOA Topic
jakwoo39
Another SOA Topic
Post by jakwoo39 »
i have a 70 series land cruiser and have started doing a SOA conversion.
leafs are out and about to go and get re-set but my big problem now is the steering
how have people done this?
im a machinist and have access to mills and CNC mills can anybody give me a sketch or drawing so i actually know what to make or perhaps pictures of their trucks
niblik
Re: Another SOA Topic
Post by niblik »
firstly, dont reset the springs chap.. ya want flat springs with a soa.. it'll keep the ride height down otherwise it'll be too rigid..
and what do ya mean the steering? as in the arms on the steering knuckles?
get some high steer arms...
it'll end up like in this sample pic...
suzolla
Post by suzolla »
Hi,
It just happens that I have a RHD kit that will save you alot of time and head scratching.
See link http://www.offroadexpress.co.nz/Forums/viewtopic.php?f=64&t=21559
Tim
jakwoo39
Post by jakwoo39 »
niblik wrote:firstly, dont reset the springs chap.. ya want flat springs with a soa.. it'll keep the ride height down otherwise it'll be too rigid..
i am going to get the springs re set 3 inches lower than they currently are which will still give it a 3 inch lift and i will actually be able to get into the truck this way. any chance you could give me the measurements off yours?
niblik
Post by niblik »
did your springs have a lift in them? you realise when goin soa you'll get a virtual minimum 4" lift anyways...?
as for measurments off mine, sorry bud, i dont have an soa on mine.. it was just a sample pic..
crazyclark31
Post by crazyclark31 »
think he ment once the soa is done and leaves reset truck will sit only 3 inch higher than it did pre soa
jakwoo39
Post by jakwoo39 »
crazyclark31 wrote:think he ment once the soa is done and leaves reset truck will sit only 3 inch higher than it did pre soa
yes if i did no modifications to the springs and did a SOA it would sit 6 inches higher than it does at the moment
but i am getting the springs set 3 inches lower than they currently are
so when i do the SOA it will only sit 3 inches higher
Fakey
Post by Fakey »
Youd be better to sell your lift springs an get a set of used standard springs. They have less leaves than the lift one so theyll flex an ride much better than reset lift springs :wink:
Having less leaves will also mean that the pack is thinner, so itll sit lower on the axle lowering your overall lift aswell.
On another note are you planning on cutting an turning the swivel balls to correct the caster angles?
Didn't barbie drive a jeep??
jakwoo39
Post by jakwoo39 »
No i dont plan to change caster angle. And the reason is. I dont think ill be lifting it enough to afftect steering and universal joints. My whole reason of doing the soa is no to clear bigger tires. It is to get the leafs up off the ground
Iv had the truck out a few times now and when i drop a wheel in a rut the leafs scrape on rhe edge of the rut and hold me up
mudlva
Post by mudlva »
i have a set off std spring that will be coming available soon
could be keen to move them on for a small donation for my beer fridge :D
jakwoo39
Post by jakwoo39 »
was also wondering what people used to make spring perches, i thought a bit of gas cut u beam?
ClassicCruiserSpares
jakwoo39 wrote:was also wondering what people used to make spring perches, i thought a bit of gas cut u beam?
I use box section 3-4mm wall, cut it to lenght, put the 3" holesaw through both sides then cut in half and you end up with two perches.
niblik
Post by niblik »
lol... bet me to it jase.. or 'c' channel notched.....
niblik wrote:lol... bet me to it jase.. or 'c' channel notched.....
I gave the discription because I new you would have pics in your archives :D
jakwoo39
Post by jakwoo39 »
awesome ill get onto those perches tomorrow.
has anybody got any idea weather i can take out the anti roll bar? will i get through cert without one
Fakey
Post by Fakey »
Yes it will
mudlva
Post by mudlva »
jakwoo39 wrote:awesome ill get onto those perches tomorrow.
turf it
you will only need the antisway if there is heaps of body roll.
and if that is the case you should be looking at the set up anyway as you will spend more time on your side than what the set up is worth
jmoo
jakwoo39
Post by jakwoo39 »
do i need to tell the cert guy so it will be certed for not having one
niblik
Post by niblik »
jakwoo39 wrote:do i need to tell the cert guy so it will be certed for not having one
best you contact your nearest certification chap and get him round. have a natter to him and explain what ya doin etc. ask him any questions and queries you may have.
be best to get him onboard early and go from there. :D
jakwoo39
Post by jakwoo39 »
ok have strated the soa and soon run into my first problem. i was under the impression that i had lift springs because of a few things.
1st. the truck easily cleared my 33x13.5 tyres
2nd the rear brake hose was way too short
but i went to 4wd panel and parts in dunedin today and bought a set of factory height springs and they are exactly the same!
so my question is was i actualy sold another set of lift springs or how can i lower my landcruiser after the soa
Fakey
Post by Fakey »
How are they the same? Do they have the same number of leaves? Think my factory rears had 5 leaves an my OME ones had about 8 leaves
Good standard 70 springs will clear 33" tyres no worries, They have 6 in the back and 7 in the front lifted do have more. You could just get the stardard springs reset lower.
crazyclark31
brown and cope ar epretty good at reseting springs.have a chat to them and they should be able to help
jakwoo39
Post by jakwoo39 »
Fakey wrote:How are they the same? Do they have the same number of leaves? Think my factory rears had 5 leaves an my OME ones had about 8 leaves
the rear ones on both sets had 7 leafs. and they were exactly the same in every way, curve, length, no of leafs and thickness
jakwoo39
Post by jakwoo39 »
the problem with getting them reset is that i will have to move the spring mounts.
could somebody that has factory springs please tell me exactly how many leafs there are on the front and rear and the thickness of all of the leafs together?
tomsoffroad
Flopsie
Post by tomsoffroad »
You wont need to move your spring mounts with standard springs. They arnt long enough to max out the shackle. :wink: I would look at doing a shackle reversal in the front. Less bump steer. Axle doesnt have to go forward to go up. :wink: Make sure your spring locating pin is free and clean with antiseize on the thread. Make it easier to remove or add springs later. Easier to tune it on the road rather than the shed :D
If you have to run swaybars so be it. Better that than hard springs
You'll blaze dude :mrgreen:
You Get That
Post by You Get That »
This is a good topic can you keep updateing it as you go along with the SOA i am planing to do this to my cruiser one day and this is all good info :mrgreen:
Addicted to suzukis....
niblik
Post by niblik »
have a look under spring over axles in here...
http://www.ih8mud.com/cruisertech.php
Fakey
Post by Fakey »
niblik wrote:have a look under spring over axles in here...
Man Ive wasted so many sundays reading thru that page :lol: :lol: great info there tho
Return to “Tool Shed”
