vh45 4.5 litre all aluminum nissan v8. Good condition, near 300hp stock, with loom and ECU.
Comes with nissan safari gearbox/transfer case which has extra clutch packs and bell housing fitted to accept the engine.
$2,000 ONO
37x12.5 r16 creepy crawlers x4. New, never driven on but have fitted to wheels. $1500 ONO
16x10 alloy wheels x4. New, have had tires fitted but never driven on. PCD 6/139.7 Offset -50 and just 11.5kg per wheel.
$1000 ONO
Nissan Safari axles, GQ, Auto, complete with disks. Can come with (cut down) chassis, arms, links, springs etc. OFFERS.
Autosport race seats x2. Steel frame. Comfortable. Fabric tatty around the base and some worn areas but more than good enough for any 4wd IMO $100 FIRM
FIBERGLASS cj3b jeep tub. New, never fitted to chassis. Rear arches tastefully cut out at the rear to give increased tire clearance. Supposed to have a RRP of around 6k I think. $1,500 ONO.
Genuine steel cj2a tailgate. Well used. Has a few holes drilled in that aren't needed and a bit of rust and dents but well useable with a bit of work.. or hang on the wall in ur shed. OFFERS.
NEW MB/GPW reproduction steel bonnet, with hinge. Painted in olive drab primer. Totally straight and as new. $150 FIRM. also have 1x pair of brand new in packet front catches for $50 FIRM
More to be added.
Can post pics for all parts below if requested.
EDIT:
ALUMINUM RADIATOR. NEW, has been sitting under my bed for the past 6 months. to fit Toyota Supra RZ TT model but will go into anything you want with a little work. Largest radiator I could find for less than $500, 400x738x50. Perfect for using as a rear mounted radiator OR in anything thats had a high performance engine transplant, 1uz or similar.
Will sell for $200 FIRM.
-Nathan
