V6 Petrol
V6 Petrol
Hi my mates V6 Terrano wont start seems to fire then floods.We have checked the ecu fault codes and get both red and green lights flashing at the same time 1 flash then 2 flashes then 3 flashes then 4 flashes then 5 both at the same time.There is nothing in his manual that relates to this.Any thoughts would be great,thanks mike.
Re: V6 Petrol
thats indicating the 5 diagnosis modes. u need to turn the screw thing back after the 3rd (I think????) flash, then it will start to flash the fault codes out
Re: V6 Petrol
Dont know if this will help, But i learnt if my sr20 floods you hold your foot hard on accelerator, and as you hear it starting to fire let your foot of slowly.
Re: V6 Petrol
Thanks Slide that worked
Re: V6 Petrol
Well that didn't work code 55 says no faults back to trawling the net for a obscure solution
Re: V6 Petrol
How long since new spark plugs have been fitted? If not recently, then try some new ones. I have personaly fixed a car that was driving along, died, and wouldnt restart. A new set of plugs and was away again! Worth a shot. Otherwise, maybe try a clamp on fuel line to trick it and lean it to get rid of flooding. It may fire up, then keep running if you release clamp at right time
Re: V6 Petrol
Yep done all that slide but still no go still checking things thou,cheers for the replys.
