hilux knuckle rebuild help
as title says, i have just brought a front axle and replacing the bearings etc, what i want to know is with the shims how many go on top and how many on the bottom, i have a rebuild kit which has 8 shims in it of 4 pairs, i know i have to put in then using a fish scale to measure pre-load or what ever it is, so can some one be able to point me in the right direction cheers, and just to let you know there where no shims with it when brought, cheers craig
Re: hilux knuckle rebuild help
I usually try to keep even numbers of shims top an bottom
Didn't barbie drive a jeep??
so is it just trying to get that preload right of 10-15lbs am i right cheers
- ClassicCruiserSpares
- Sausage Shack
Fakey wrote:I usually try to keep even numbers of shims top an bottom
I agree thats how I do mine too, Untill the preload is rite.
Yeah you just put shims in or remove them till ya get the desired preload
