now 4 sale 33" maxxis bighorns and turned rims for sale
- Spring Free
have a set of 33" bighorns on 15x8" rims with turned centers to give wider offset,they are currently on a swb cruiser.still have heaps of tread left $640 no reserve,listed on trademe [url][/url] Thanks Rich.http://www.trademe.co.nz/Browse/Listing ... =392568233
Re: 33" maxxis bighorns and turned for sale
Any idea on the offset?
- Spring Free
Re: 33" maxxis bighorns and turned rims for sale
will have a measure up tomo night,do i measure from the face that goes against drum to the outter side of the rim?
Very keen! how many mill tread left?? Cheers
muddyplumber wrote:will have a measure up tomo night,do i measure from the face that goes against drum to the outter side of the rim?
Rim Measurements
Wheel Backspace
This is the distance from the back edge of the wheel to the hub mounting surface. To determine the wheel backspace:
Position the wheel face down.
Lay a straight-edge across the back of the wheel.
Measure the distance from the straight-edge to the wheel's hub mounting surface.
Wheel offset
The wheel's offset is the distance from its hub mounting surface to the centreline of the wheel. To determine wheel offset:
Position the wheel on a flat surface and measure its overall width.
Divide the overall width by two, then subtract this result from the backspace value.
Offset = Backspace - (Rim Width / 2)
The offset of a wheel can be one of the following three settings:
Zero offset:
The hub mounting surface is even with the centreline of the wheel.
Positive offset:
The hub mounting surface is toward the front or wheel side of the wheel. Positive offset wheels are generally found on front-wheel drive cars.
Negative offset:
The hub mounting surface is toward the back or brake side of the wheel's centreline. "Deep dish" wheels are typically negative offset.
Ph 0212078472
Ph 0212078472
- Spring Free
Heading up the ski field today but will measure everything when I get back,thanks for the diagram
muddyplumber wrote:Heading up the ski field today but will measure everything when I get back,thanks for the diagram
Sounds good mate, If its easier give me a txt, 0274726983. Cheers
Im interested in just the mags (depending on offset) if someone wanted just the tyres.
id be keen on just the tyres...
You'd probably be better off on TM, let there be a bidding war so you get the best $$$
axel wrote:Im interested in just the mags (depending on offset) if someone wanted just the tyres.
I'll take just the tyres, Been what I have been after for awhile.
- Spring Free
Sorry everyone but set of tires I was gonna buy have fallen thru so will keep these.rich
muddyplumber wrote:Sorry everyone but set of tires I was gonna buy have fallen thru so will keep these.rich
Guttered...
- Spring Free
Re: now 4 sale 33" maxxis bighorns and turned rims for sale
have now edited top post,are listed on trademe.these are up for sale,ended up getting 35 creepys.Rich
muddyplumber wrote:have now edited top post,are listed on trademe.these are up for sale,ended up getting 35 creepys.Rich
Would you do $650 buynow? Cheers
Grrr why now!!
Really want some 33s!
Hugo -02102470477
- Spring Free
May take 650 at the end but want to let auction run,think it finishes Thursday.Rich
