H25 to replace H20
For all Suzuki related topics
mudbugga
H25 to replace H20
Post by mudbugga »
I can get a low k's H25 for a reasonable price.
It will work out cheaper than replacing the chains on my H20.
Apparently you can swap the H20 for the H25 without too much hassell. Just need exhaust and ECU. All the auxillary things can be swapped from the H20 onto the H25.
Has anyone done this swap?
What did you discover that I should know?
benorange
Re: H25 to replace H20
Post by benorange »
its meant to be easy. it all bolts up. as far as getting to run aparartly you need to swap a few bits off the 20 onto the 25. and it will run on the 20 computer. look through the earler threads for v6 needed posted by me there is a good link an there
lexulance
Post by lexulance »
Yes it is a bolt in job,just swap the h25 injectors to the h20 manifold and away you go,and as a previous reply said swap the coils from the h20 over aswell, also use BKR6E plugs not 11s although this only effects the autos operation if you use 11s instead.
Have done this swap a few times at work as h20s are getting hard to find in good order :)
mudbugga
Post by mudbugga »
Cheers guys.
What's the deal with those spark plugs affecting the auto operation?
All the 11 in the number indicates is the factory preset gap of 1.1mm.
Mines a manual so no auto dramas. :wink:
Still deciding whether to do it or just flick the Zook and get another or a bigger 4wd.
tow99
Post by tow99 »
The number in the spark plug code is the heat range not the gap
mudbugga
Post by mudbugga »
tow99 wrote:The number in the spark plug code is the heat range not the gap
You're right, but the "11" at the end of the number (ie BKR6E-11)
is the factory gap set to 1.1mm.
http://www.ngksparkplugs.com/docs/tech/ ... _plugs.pdf
Without that "11" at the end the gap has been set in the factory to 0.8mm.
Don't know why that would effect the auto operation though.
strx7
Post by strx7 »
you need to use the H20A injectors, if you use H25A ones with the H20A ecu and electrics it will drink fuel like a V8. the H25A injectors flow more than the H20A ones do..
H25A block/heads etc with all H20A electrics and away you go.
Return to “Suzuki”
