Isuzu MU Rear( Crank seal)
For all Isuzu related topics
oldblue
Post by oldblue »
A friend has replaced the rear crank shaft Seal 3 times and 3 times it has failed.Started off with aftermarket brands, then even fitted a genuine seal.Still leaked, The last one was fitted by a garage. Have now been told that you need to fit a Speedy Sleve even tho the surface is in perfect condition. Has anyone had this same problem.
Its a 92 4ZEI motor 2'6 petrol
Aaron
Post by Aaron »
I have had that problem before with no genuine seal but it was ok with a genuine one.
I would be looking at the PCV valve on the valve cover to make sure the engine is pressurising the crankcase and forcing the oil out.
Toyota 70 series cruiser, 13bt
Phone 029 454 8533
oldblue
Post by oldblue »
They have just fitted a genuine seal and tapped in to the houseing so that the seal is flush with the seal houseing, (not any deeper) and this seams to be working OK. Thanks
Return to “Isuzu”
