LOCKRITE LOCKER for Dana 44
Quick queston..can a Lockrite or Lokka diff lock be fitted into 44 Dana diff that has LSD [ after LSD has been removed ] or can they only be fitted to open diff's ..Cheers Furnace
Re: LOCKRITE LOCKER for Dana 44
Dont see why not. If you can put an airlocker in.........
/| , [____],
l----L -OlllllllO-
()_) ()_)-----)_)
KEEP'N JEEP'N!
l----L -OlllllllO-
()_) ()_)-----)_)
KEEP'N JEEP'N!
xj wrote:Dont see why not. If you can put an airlocker in.........
I think so to but just not quite to sure as i have seen some where that they could not be fitted to another 4x4 that had a LSD [ not sure what it was now ] he had to buy a open diff, I think i read it in Aussie 4wd very recently
An air locker comes with it's own "carrier" a "lock right" does not, you fit it to your existing carrier. I am un-sure if you can fit a lock right type to a LSD carrier, but if you find you cannot, I have a D44 open carrier if you need it.
You also may not be aware, that when you do replace the carrier, you will need to "re-shim" for the correct backlash.
Bernie.
Bernie.
bernie wrote:An air locker comes with it's own "carrier" a "lock right" does not, you fit it to your existing carrier. I am unsure if you can fit a lock right type to a LSD carrier, but if you find you cannot, I have a D44 open carrier if you need it.
Bernie.
Hi Bernie,many thanks for that,definitely a grey area at the moment..lol I have had air lockers in the past but at the moment do not want the expense
