Have been looking at the runva winches on trademe and have come across these two
http://www.trademe.co.nz/Browse/Listing ... =391138557
and
http://www.trademe.co.nz/Browse/Listing ... =391373305
I'm kind leaning towards the 9500lb on as it has a 10hp(8kw)
motor so would think it has a bit of line speed. Problem is the gear ratio is pretty high at 110:1
The 12000lb one only has a 5.5hp(4.2kw) motor but a good gear ratio of 233:1 problem is it would be blimmin slow and can't stand it when waiting on a slow winch to do its thing
as i've done a couple of comps now i kinda like a bit of rope speed but will the 9500 handle a big truck stuck in a bog?esp with that ratio.Am thinking the high output motor will help with this tho.
Also would the standard crappy safari alt handle that kinda drain? Truck has two new 700cca bats
Man i wish could put my pto on instead!!!!
