Nissin Safari TD42 None Turbo.
Has anyone had Surging when cruising at 1100 RPM .50KM/H. Top gear only, No other speed or rev's. I have been told it happens in other Nissin's. Is there a fix for this?
Nissin Safari ( Surging)
I would look at the fuel filter first and get the injector timing checked, or if that doesnt work get the injectors serviced they might need some new nozzles to get a good fine spray pattern.
Also put some deisel treatment in the tank just in case ther is some diesel bug in there.
Toyota 70 series cruiser, 13bt
Phone 029 454 8533
Phone 029 454 8533
