Nissin Safari ( Surging)
Posted: Mon Jul 10, 2006 6:53 pm
by oldblue
Nissin Safari TD42 None Turbo.
Has anyone had Surging when cruising at 1100 RPM .50KM/H. Top gear only, No other speed or rev's. I have been told it happens in other Nissin's. Is there a fix for this?
Posted: Mon Jul 10, 2006 6:59 pm
by mudchuka
mine some times surges at idle, try changing the fuel filter .
Posted: Sun Sep 10, 2006 6:51 pm
by 3rnzir
You didn`t put any of that kero based fuel treatment into your tank did you?
Posted: Mon Sep 11, 2006 4:58 pm
by hiluxDave
it could be your injectors
iv got a mate that had the same prob mostley at 100kph and a heap of black smoke blowing.
Posted: Mon Sep 11, 2006 5:37 pm
by oldblue
Apart from the serging, the motor run spot on. No black smoke, clean running pipe, etc
Posted: Mon Sep 11, 2006 6:15 pm
by fearless
happend to my dads a while back.but this was a 96 terrano with the qd32 engine.would surge and sometimes completely stall randomly.engine check light would also come on and off.was very expensive to fix.
this is what happened to ours but could be something totaly different in your case.
Posted: Mon Sep 11, 2006 6:40 pm
by Aaron
I would look at the fuel filter first and get the injector timing checked, or if that doesnt work get the injectors serviced they might need some new nozzles to get a good fine spray pattern.
Also put some deisel treatment in the tank just in case ther is some diesel bug in there.
